Selection of entities
I have noticed on V25 that when you have lets say 2 lines on top of each other (different or same layer) for whatever reason or near by, a box appears asking which entity you want to select. at first i was ok and went with it get used to it but after a well it get me frustrated and slows me down. Is there a setting to turn off that feature or i just need to live with it. thanks
  • The appearance of this selection dialog is controlled by SELECTIONCYCLING system variable, you can choose for example displaying of a badge only (value 1) or turn it off (value 0).
  • thank you…
