How to Parametrizing an Angle in BricsCAD
Hello everyone,
I am currently in the process of transitioning some workflows in our CAD library from dynamic ACAD blocks to parametric BricsCAD blocks while also adding new features. However, I’ve encountered a major challenge when trying to parametrize an angle.
A simple example: I want to parametrize a 3D solid beam.
  • The material cross-section should be selectable via a design table.
  • The length should be adjustable via a user parameter.
So far, so good. Now, I also want to be able to angle the ends of the beam and parametrize this property. The goal is to control the following aspects via parameters:
  • Cross-section
  • Length
  • Miter angle at one end
  • Miter angle at the other end
I have spent several hours experimenting with parametrization, especially using the Angle Constrain, but I can’t get a proper output. Either nothing happens, or the part gets completely deformed.
Does anyone have experience with this? Is there a reasonable approach to parametrically controlling the angles of the beam ends, or is this not really intended in BricsCAD?
Thanks in advance for your help!
  • Hello.
    The geometric kernel, ACIS, has some limitations when it comes to parametrizing a 3D model.
    So, some things might not work.
    For this case, the attached model could be used as a start point.
    The safest approach would be to use it as a block, inserted into another drawing.
