How to fix the dimension and insertion snapping
in 2D Drafting
Hi guys,
My cursor's UCS seems to snap weirdly to the lines which causes the dimenstions and several other entities to snap in odd ways (even though UCS is set to world). How do I fix this so it's always on the same axis? It's probably a setting I've accidently changed somewhere in the program.
Check this youtube video where you can see it:
Have you got Dynamic UCS switched on?
1 -
You are a lifesaver. DUCS was indeed on. I turned it off and now it's fixed. Thanks alot!
Wow, I seem to be becoming one of those old-timers!
