Imported Images not showing on re-open
SticksAndBrics
edited February 2025 in 2D Drafting
Hi, I'm finding since my laptop was updated to Bricscad 22.2.06, that many of my imported images (such as my client logos, or the OS raster mapping) will load in just fine, and for some jobs be unchanged forevermore.
But then for others I simply get the file path name shown in the outline of where the images used to be (see attached).
(Road closure TM plan, with image not found it would seem)
(Client logo box within my template, another shared folder)
The folders aren't changing, though they are part of a shared drive if that makes a difference? I have previously kept he files locally on my PC but have learned that this is unhelpful for other CAD users that open the same projects as me but don't have the files saved locally in the same directory.
I'm basically asking if this is something that is either a known issue, or if there's a simple workaround that can prevent this from happening in future?
Many thanks folks, keep on cadding
  • Hello.
    The first thing would be to check what type of paths are set for attachments - relative or absolute.
    Then, check whether the paths are valid and the files are placed as set.
    With the first image, the path seems to be relative, pointing to a folder located two levels up relative to the location of the main drawing.
    With the second image, I am not sure.
    Relative paths use some symbols, like .\ for folders on lower levels and ..\ for folders on upper levels.
    In this case, the symbol is missing.
    Also, the path doesn't seem to be an absolute one.
