Cut away, Hidden, Background lines
Hello,
is it possible to set the depth of the geometry to show these (Cut away, Hidden, Background lines)?
Thanks
  • Change the settings for the visual style.
  • Thank you for the reply.
    I meant in BricsCAD BIM when creating sheets I want just to show hidden lines e.g. 1000mm below the section plane and cut-away lines 1200mm above the section plane. Here is a comparision - on the left there is a sheet created with default settings and on the right my Typed Plan with "Type(BIM) is Wall" Hidden lines. They are pink just to see how they appear. Now I would like to see only hidden geometry like the wall under the sill etc. Those red-crossed pink lines are the foundations and I do not want to see them.
