Lag loading BricsCAD
We have several workstations running BricsCAD 24. On two of the workstations the time taken from clicking on the icon to BricsCAD appearing is a matter of seconds. On the remaining workstations it is taking around 60 seconds. IT has advised me that the setup on all the workstations is the same.
Has anyone else experienced this problem and is there a solution.
Thanks in advance.
Going from memory, this could have to do with your LAN. I'd check the SRCHPATH settings to be sure the folders that are called out are in the correct order and verify that the folders exist and are reachable. 60 seconds sounds like something is timing out.
1 -
This problem may be posted elsewhere, suggested look at PC's are they using SSD drives, how much ram etc. We set up the temp directory to a local drive to take load off the server.
maybe start a new profile and see what happens
