Radie command with a distance
Njanja
edited March 2025 in 3D Modeling
Hello everyone,
am doing an exercise but got a bit stuck.
In the picture I am going to make a radius (R4) with a distance of 6 mm.
Tried both with “Fillet” and “Chamfer” command but unfortunately not successful.
My question is should I do it in a different way or I do in the wrong order?
  • Hi Njanja
    I assume you are trying to create a solid model of this.
    See the image below.
    Hope this helps with your approach to solid modelling.
    Regards
    Norbert
  • Hi there,
    was a bit busy, could not answer.
    But your tip was perfect.
    Words cannot describe how grateful I am.
    best regards
    Njanja
  • norb1@bigpond.com
    edited March 2025
    Hi Njanja
    Thanks and you're welcome.
    Cad offers many ways to approach a problem. Think laterally and you'll eventually
    develop your own methods.
    Or, you can always find answers here.
    Norb
    P.S negative fillets are not a thing in cad.
