Assembly function.
Hi All
Working on 3 drawings to be put together.
The idea was to put them together using the Assembly function.
Looked a little on youtube and succeeded a bit but not as I want.
Wondering if there is any good exercise or video that shows step by step how to do.
Or can make a short video with all the steps.
It does not have to be so advanced. Just that you learn the technique.
  • What is exactly the issue you are running into. I am assuming you are using mechanical components/blocks or existing sub-assemblies to create a main assembly.
    Maybe the video below may be of some help, otherwise feel free to ask more specific questions.
