After crash I have this corrupted file
Good morning
I searched but I didn't find anything, maybe you can help me.
after a crash When I open the file .DRW bricscad open also this file: Drawing in "name file"
When I try to close it, it does but in command bar shows: Error executing "WCLOSE"
The Drawing in "name file" is an old version of the actual file
If I close the Drawing in "name file" it overwrite the real file. Unacceptable
I tried to save as, didn't it well. this is the crash report of the command.
Someone can help me? thanks!!
P.s
I cannot share the file in question
This is when I try to copy paste part of the .dwg
It creates 3 Drawing in "drawing2"… I need this file :(
Edit:
I also tried to insert the drawing as block inside a new .dwg
miserably failed
I also tried to export as .dxf…. nothing works1 -
maybe a utility program like this will help
I have office's computer, it is locked😓
tks for the reply0
