BricsCAD + Grasshopper - Layers
Hello,
Is there a way to retrieve the name of the layer on which a given element is located in BricsCAD space within a Grasshopper script?
Additionally, is there a way to BAKE an element into BricsCAD directly onto a specific layer without having to select it from a dialog box?
I am trying to write a GH script that generates 3D elements based on a drawn curve as the cross-section of a given element, and I want to automate the process of assigning elements to the appropriate layers after BAKE.
Thanks.
I share the same idea as well, and I have mentioned SR before. But so far, there has been no response. I also want to search for the material.
