arrow leader not showing
Does anyone know why the arrow leader is not showing on the below?
I have select DIM LINE 1 :
If I select Dim line 2 already shows the arrow leader:
Any reason for this to happen as I really need to use DIM LINE 1
Thanks
If this is not resolved yet, could you please attach the dwg file here?0
question 1, what version of Bricscad are you using?
question 2, do you use dimstyles?0
