Version 25.2.03-1 Selecting cuTting edges mode in TRIM causes crash
JorisHoogstede
edited March 2025 in 2D Drafting
Curious if i'm the only one here:
When selecting the TRIM command and then entering T to select cutting edges makes the software crash instantly :-(
Been working two days with this version, but I'm going back to a previous version. This one has too many errors for me for a 'stable' release.
Please Bricsys, do your homework and don't release a version that contains this kinds of errors (as mentioned before in another post the Layer Control in the ribbon has a bug).
Small edit: just filed the bug and found as a small workaround for now the TRIMEXTENDMODE and set the value to STANDARD
  • You are not the only one) The same was reported for Beta, and development task has been created, as I know.
  • Any solutions as it crashes everytime use trim or extend :-(
  • Download the latest version 25.2.04-1 which was released last week. The issue is fixed in that release and trim and extend work normal.
