Version 25.2.03-1 How to turn off SELECTIONCYCLING completely at MATCHPROP?
I think I've tried all the settings (-2 /-1 / 0 / 1 / 2), but it keeps popping up when I MATCHPROP properties of an object to another.
Am I missing (another) setting/variable or is it a bug in this version?
It seems that it only works the first time I set it to 0, but a second time I run MATCHPROP the selectioncycling display pops up again.
Seems to work here.
As a workaround, set SELECTIONPREVIEW system variable to Off.
This error seems to happen when the QUAD is used for commands. Nothing is wrong with the selectioncycling setting as long as you don't use the QUAD. But once you do the selectioncycling window pops up and the stored setting is ignored.
