Testing the Image Button
Saitoib
edited March 2025 in LISP
Hi all.
I can't get the dialog image display to work
What is wrong with the following sample?
Thank you.
test1:dialgo{
label = "Testing the Image Button";
: image_button {
key = "image_btn";
label = "image";
width = 50;
height = 50;
fixed_width = true;
fixed_height = true;
image = "image";
ok_only;
There was an error in the uploaded code, which has been corrected.
  • Here is a lisp that makes 3x3 or 4x3 dcl on the fly may give you the answer your looking for or this other one for drawing a kitchen table. And a just display a slide. Trying to find draw table.lsp code.
    (defun Splash (s w / sn dcl-fn dcl-fp dcl-id x y)
    (vl-load-com)
    (cond
    ((not (= (type s) 'STR))(princ (strcat "\nInvalid slide name : " (vl-princ-to-string s))))
    ((not (setq sn (findfile s))) (princ (strcat "\nSlide not found : " (vl-princ-to-string s))))
    ((not (= (type w) 'INT))(princ (strcat "\nInvalid value for delay : " (vl-princ-to-string w))))
    ((not (and (setq dcl-fn (vl-filename-mktemp ".dcl")) (setq dcl-fp (open dcl-fn "w")))) (princ "\nUnable to show slide"))
    (t (write-line (strcat "im:dialog{label="Alan H Consulting ";:image_button{key="im";color=-2;width=60;"
    "aspect_ratio=0.5;allow_accept=true;is_default=true;}}") dcl-fp)
    (close dcl-fp)(gc)
    (setq dcl-id (load_dialog dcl-fn))
    (new_dialog "im" dcl-id)
    (setq x (dimx_tile "im") y (dimy_tile "im"))
    (start_image "im")
    (slide_image 0 0 x y sn)
    (end_image)
    (wait w)(term_dialog)(if dcl-id (unload_dialog dcl-id))(if (and dcl-fn (findfile dcl-fn))(vl-file-delete dcl-fn))
    (princ)
    (defun wait (sec / stop) (setq stop (+ (getvar "DATE") (/ sec 86400.0))) (while (> stop (getvar "DATE"))))
    (Splash "LOGO.sld" 2)
