Floor elevation
I am a bit into Python, testing some small scripts for BricsCAD.
Any ideas how to get Floor elevation? I want to use it to automatically get Window sill height.
  • You need to explain more about what makes a window are you using BIM, is it a block and so on.
  • OK.
    It´s standard default BIM Window in BricsCAD BIM. In the Properties panel there is the Sill height. But it is "0mm" by default even if the window has no-zero sill height and has to be written manually. I would like the script to set it automatically.
    Something like this:
    SillHeight = Geometry/PositionZ - Window/Floor elevation
