Wayland black window and Crash report
in Linux
I'm trying to use Bricscad with the version of 25.2.03 in an Arch based system Garuda with following system specs.
OS: Garuda Soaring Broadwing
Kernel: x86_64 Linux 6.13.8-zen1-1-zen
Uptime: 56m
Packages: Unknown
Shell: bash 5.2.37
Resolution: No X Server
WM: Hyprland :D
GTK Theme: Sweet-Dark [GTK2/3]
Icon Theme: Adwaita
Font: Fira Sans, 10
Disk: 2,6T / 3,2T (82%)
CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx @ 8x 2.3GHz
GPU: AMD/ATI Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
RAM: 5613MiB / 14913MiB
I solved library issue global definition in the .bashrc file and then run ./bricscad file in the custom installation.
I get only black screen as follows when I invoke ./bricscad file meanwhile terminal says (bricscad:19442): Gdk-CRITICAL **: 14:11:39.317: gdk_x11_window_get_xid: assertion 'GDK_IS_X11_WINDOW (window)' failed
I think the problem is Wayland and X11 incompatibility. When I kill the process getting an crash report in the current directory.
The program has crashed
Reason: Illegal access: Address not mapped to object on address 0x8
Crash report has been written to "crash_report.txt".
the crash report
--------------- 24-03-2025 14:08:53 --------------- v25.2.03.0 ---------------
Linux version 6.13.8-zen1-1-zen (linux-zen@archlinux) (gcc (GCC) 14.2.1 20250207, GNU ld (GNU Binutils) 2.44) #1 ZEN SMP PREEMPT_DYNAMIC Sun, 23 Mar 2025 17:17:17 +0000 Illegal access: Address not mapped to object on address 0x8
Call stack (current) (main):
/home/x/Downloads/bricscad/libbcutils.so(+0xeb4ba) [0x74eff7ceb4ba]
/usr/lib/libc.so.6(+0x3dcd0) [0x74eff764bcd0]
/home/x/Downloads/bricscad/libQt6Core.so.6(_ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent+0x78) [0x74eff9d3d618]
/home/x/Downloads/bricscad/libqtgui.so(+0xb88d8e) [0x74f001188d8e]
/home/x/Downloads/bricscad/libqtgui.so(+0xb89060) [0x74f001189060]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler23ProcessEventIfMatchesIdERK21wxEventTableEntryBasePS_R7wxEvent+0x6e) [0x74f001fa6dde]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler23SearchDynamicEventTableER7wxEvent+0x7e) [0x74f001fa715e]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler11TryHereOnlyER7wxEvent+0x24) [0x74f001fa72c4]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler19ProcessEventLocallyER7wxEvent+0x2f) [0x74f001fa736f]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler12ProcessEventER7wxEvent+0x69) [0x74f001fa7419]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN12wxEvtHandler18SafelyProcessEventER7wxEvent+0xb) [0x74f001fa7e4b]
/home/x/Downloads/bricscad/libwx_gtk3u_core-3.1.so(+0x361d62) [0x74f001761d62]
/usr/lib/libgtk-3.so.0(+0x2b8815) [0x74f0024b8815]
/usr/lib/libgobject-2.0.so.0(g_closure_invoke+0x172) [0x74f003db2812]
/usr/lib/libgobject-2.0.so.0(+0x41f85) [0x74f003de2f85]
/usr/lib/libgobject-2.0.so.0(+0x3248f) [0x74f003dd348f]
/usr/lib/libgobject-2.0.so.0(g_signal_emit_valist+0x42) [0x74f003dd3f72]
/usr/lib/libgobject-2.0.so.0(g_signal_emit+0x94) [0x74f003dd4034]
/usr/lib/libgtk-3.so.0(+0x59a8ed) [0x74f00279a8ed]
/usr/lib/libgtk-3.so.0(gtk_window_propagate_key_event+0xec) [0x74f0027aa61c]
/home/x/Downloads/bricscad/libwx_gtk3u_core-3.1.so(+0x357f46) [0x74f001757f46]
/usr/lib/libgtk-3.so.0(+0x426aba) [0x74f002626aba]
/usr/lib/libgtk-3.so.0(gtk_main_do_event+0xc4b) [0x74f0026277bb]
/usr/lib/libgdk-3.so.0(+0x27457) [0x74f004afd457]
/usr/lib/libgdk-3.so.0(+0x62210) [0x74f004b38210]
/usr/lib/libglib-2.0.so.0(+0x5e104) [0x74eff4b06104]
/usr/lib/libglib-2.0.so.0(+0xc1d57) [0x74eff4b69d57]
/usr/lib/libglib-2.0.so.0(g_main_loop_run+0x137) [0x74eff4b06de7]
/usr/lib/libgtk-3.so.0(gtk_main+0x8f) [0x74f002624dff]
/home/x/Downloads/bricscad/libwx_gtk3u_core-3.1.so(_ZN14wxGUIEventLoop5DoRunEv+0x25) [0x74f0017469a5]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_ZN15wxEventLoopBase3RunEv+0x31) [0x74f001eafb31]
/home/x/Downloads/bricscad/libwx_gtk3u_core-3.1.so(_ZN8wxDialog9ShowModalEv+0x24d) [0x74f0017a050d]
/home/x/Downloads/bricscad/libqtgui.so(_ZN3qtg11dlgLauncherEv+0x260) [0x74f001158250]
/home/x/Downloads/bricscad/./bricscad(_ZN3wxc6WxcApp8startAppERK8OdString+0x1cb) [0x5b9c9c2b572b]
/home/x/Downloads/bricscad/./bricscad(_ZN3wxc6WxcApp6OnInitEv+0x7b8) [0x5b9c9c2b6e58]
/home/x/Downloads/bricscad/libwx_baseu-3.1.so(_Z7wxEntryRiPPw+0x72) [0x74f001ef0ac2]
/home/x/Downloads/bricscad/./bricscad(main+0x132) [0x5b9c9c2ab622]
/usr/lib/libc.so.6(+0x27488) [0x74eff7635488]
/usr/lib/libc.so.6(__libc_start_main+0x8c) [0x74eff763554c]
/home/x/Downloads/bricscad/./bricscad(_start+0x25) [0x5b9c9c2aee55]
