Redefining ctrl-middle mouse button
If I disable the default mouse shortcuts using CTRLMOUSE set to 0, then can I redefine these shortcuts?
I would like to use ctrl-middle button (and maybe shift-middle button) to enact realtime zoom (similar to what ctrl-shift-left button does when CTRLMOUSE = 1). I would like to be able to use this realtime zoom in the middle of a command, without having to "exit" from it as one does when using the RTZOOM command.
Hello.
You could experiment with adjusting the current cui file, or maybe creating a partial customization file.
Use the CUSTOMIZE command and activate the Mouse tab.
Then, expand the nodes, Ctrl+Click and Shift+Click.By default there are two empy items for each, the first is for the right button, the second is for the middle button.
Right-clicking on an empty item allows to insert a button (tool) and assign a command to it.
The next article contains more information about this topic.
