Behavior change in _insert command?
Latest Brics version. When I insert a block with text, then explode it the text becomes mirrored. Didn't do this before, block rotation and orientation was always working ok. Anybody else see this?
Ok I looked into this further and discovered in the _insert command when inserting a block using the "on screen" prompts after inputting a scale factor for "X" the prompt defaults to the negative equivalent for "Y".
When I enter in the scale values from command line this doesn't happen. Don't know what's going on but this is where I'm at. Definitely didn't do this for me on prior versions. See attached screenshot if that helps.
I'm going to file a support request on this one in case I'm missing something or in error somehow. It's not a show stopper but it's the 2nd instance where I have to take extra steps where in prior version I didn't.
If you do Inset so insert screen comes up have a look at the Y. I set it to -1 for testing, click Specify on screen maybe. Or set to 1 it does make a difference.
ALANH,
I looked at the dialog box again and noticed there's a "uniform scale" toggle at the bottom. Never noticed that before, probably need thicker glasses 😁. Anyways after toggling that it's fine now.
