View/Rendering/Modeling - getting artifacts
Hello,
When using modeling view, i now get weird artifacts in the shape triangular borders and somesort of transparency all around.
How can I fix this? (I'm using version 25.1.06 BIM)
1
Could be a GPU problem or a GPU driver problem.
(weak onboard GPU in use instead of the dedicated GPU)
or because the geometry is too far from internal origin ?1 -
Some of the artifacts in the lower right seem to come from intersecting/coincident surfaces. The triangular artifacts look like they have a different cause.
Is there a different than usual view style active, a change in some layer properties with regard to transparency settings?
1 -
I guess I solved it updating the GPU driver.
Thanks Zoomer,
Thanks RSW.
2
