Disable Recovery Manager Panel
After BricsCad crashed, the Recovery Manager Panel is shown on the next start. Is there a way to avoid this? I would like to completely disable the Recovery Manager Panel.
  • Unless this behaviour is new in the latest V25 release it should not who automatically. Usually there is a small popup window in the lower right corner after a restart after crashing. There you can select to open the Drawing Recovery Manager.
    If it is open, then try closing it by right-mousebutton clicking in the ribbon area and deselect Drawing Recovery Manager from the Panels section in the pop-up menu. Then the Drawing Recovery Manager panel should no longer automatically come up until you do that yourself.
  • Unfortunately, this doesn't resolve the issue, as the Drawing Recovery Manager reappears after the next crash.
    I'm a developer, and it's quite common for me to end a debug session in Visual Studio, which seems to trigger the described behavior.
    Additionally, I would also prefer not to see the popup window in the lower-right corner. ;-) For reference, here are the variables I currently have set for tray icons:
    TRAYICONS = 1
    TRAYNOTIFY = 1
    TRAYTIMEOUT = 1
    Any more ideas how to stop Drawing Recovery Manager to show up?
  • I noticed there is a command DRAWINGRECOVERYHIDE, so I tried to call it in my on_doc_load.lsp:
    (command "_DRAWINGRECOVERYHIDE")
    But it seems that the Drawing Recovery Manager is opened after the lsp is executed. 🤔
  • Owen Wengerd
    edited March 2025
    Maybe try (defun S::STARTUP () (command "_DRAWINGRECOVERYHIDE")) in your on_start.lsp.
  • Unfortunately, this didn't work. Even if I use the DELAY command to wait 5s before_DRAWINGRECOVERYHIDEthe Recovery Manager Panel opens afterwards.
  • If there is currently no solution to my problem, I would like to submit a feature request for a new option to disable the Recovery Manager Panel.
