Pan Command gets stuck
I use the mouse wheel button to pan , and after removing my hand of the button it gets stuck on the pan command i cannot pan again , even after pressing the ESC or the space bar it does not go back to normal
I switch to other app and come back the pan function works good the first time and then the same issue occurs
The drivers of the mouse are up to date and i also tried different mouse , but the same issue persists
Could anyone help me , if you found the solution for this issue.
I use version V 22.2.06 (x64)
Bricscad with this all this while no issues , suddenly out of nowhere this issue occurs
What mouse are you using? It could be a driver issue with the most recent mouse driver or the most recent graphics card driver in combination with BricsCAD which was also recently updated. Occasionally the cursor is getting stuck in BricsCAD but not other programs as far as I can tell.
