Drop down button
The drop down buttons refuse to work on my V25 Bricscad. The only solution is to restart Bricscad and load the work again, but after a while the problem comes back. I searched here in the forum, and I see that the problem is know since at least 6 months now. I can't understand that this is not solved yet. Due to that problem I have to return to V24, … again.
Maybe Bricscad is a cheaper solution, but probably a lot more expensive when I could calculate the effective useful time against my lost time.
I'm not sure which exactly problem do you mean, and if development task exists for it, but if you have a Maintainance it's worth to create a support request to add value to existing task or to initiate its creation.
