Alternative for mouse an keyboard (Spacemouse, touchpad?)
Since a few month I do more and more drawing work and I using BIM instead of 2D. I notice that I start get some wrist problems. I'm working with a keyboard and a 3Dconnexion CadMouse with af 3Dconnexion mousepad. I'm thinking about buying a Spacemouse, but I`m afraid that will not be enough because I will still use the mouse. I'm thinking about a touchpad but is that any good voor BIM modeling? What are you guys using?
  • Tom Foster
    edited April 2025
    https://www.dxtmouse.com or similar is the answer - read it carefully.
    The only trouble with the DXT is that the 'push to click' action of its middle button gets so excessively used with panning in Bricscad, that it stops working. I've had a series of DXT mouses replaced FOC because of this, and I've investigated replacing its microswitch with something more robust, no luck. DXT is superb, the best, but there are alternatives.
    I use my Spacemouse for pan/zoom/rotate anyway.
