Point Nodes
Which would be your choice of BricsCAD versions for surveyors who do not need 3-D modeling, but who wound like to use LISP programming to generate point nodes and markers similar to Autodesk Civil 3D?
  • If you want surfaces, load points etc then you need the pro version. the Lite version has lisp but may lack some features that you need as a surveyor.
    I would look at "Stringer" and "Civil Site Design" also, these sit on top of Bricscad and will should give you all the features you will need. Just do a google.
  • @ ALANH
    I can’t afford add-ons like Stringer and Civil Site Design. Is the pro version of BricsCAD more adaptable to LISP programming as compared to the basic version?
  • No difference in Lisp itself. But if a particular Lisp function calls a command that doesn't work with Lite, then that function won't work with Lite either. And Lite doesn't support Visual Basic and C++ apps.
    In the Command Reference (https://help.bricsys.com/en-us/document/command-reference?version=V25&id=165079036112), the page for each command tells you which license levels it works with.
    The 30-day free trial can be run as any version you want. Just change the license level (with the SETLICENSELEVEL command) and re-start.
    If you buy the Lite version and then decide you need a higher level, you can upgrade by paying the difference.
  • @ Anthony Apostolaros
    Thank you for the valuable information.
