Help with a alignment feature?
In the last versions of V24, we seem to have got this feature where the axis aligns to and object when overing over it. It can be useful but not so just as often. I don't know what this feature is called, but is there a per instance option to disable and or permanent toggle?
Simple example, I have a diamond, and I then move a square to it, the square will orientate to the diamond rather than staying in its original orientation.
Does that make sense lol.
