ArcAlignedText Workshop dialog box
please help. when I select arc text under expresstools the ArcAlignedText Workshop dialog box does not appear. I only get to utilize the command line prompt to input text, and pick arc. I am not able to change the font.
Which BricsCAD version do you use? This sounds like you are using BricsCAD Lite older then V24. It had a restriction of ARCTTEXT command: the 'ArcAignedText Workshop' dialog used an OpenDCL dialog, based on BRX, but BRX is not available in Lite version.
So in Lite version only simplified command line version of ARCTEXT command was available. The only properties that could be edited are the ones presented at the Properties Panel: contents, height, width factor, arc offset, left offset, right offset.
But in V24 ARCTEXT is re-implemented using WxWidgets, so the dialog should work in Lite version also.0
