Display problems on LG Gram Laptop Version 25.2
Version 25.2.4 is not displaying entity selection, erase, and undo correctly
When an item is selected and erased only the grips disappear until a "manual" redraw is activated by wheel zoom, or highlight of a line on hover. Likewize, when undo is selected, the command line updates with the command, but the display itself does not update until a wheelzoom is done.
I am running a "stock" LG Gram Laptop I7 with an Intel 620 graphics card (pretty generic)
Version 25.1.7 works fine, so I think it is related to the font scaling implementation in 25.2
The problem occurs booted in safe mode as well as normal mode
Any clues out there would be appreciated
  • I found a partial work around by redefining the DELETE key to "erase redraw". Undo is still broken and does not update the screen until the cursor is back on the screen (not toolbar area) and/or a wheelzoom is issued.
  • This sounds like a frustrating issue, especially since everything was working fine in version 25.1.7. It does seem like something changed in the display or font scaling with 25.2, so hopefully the developers can look into it and provide a fix soon. Thanks for sharing the workaround, too!
  • Just a comment a few versions ago with Autocad had a problem with the onboard Intel graphics, we had to get new Pc's with a Nvidia etc, sounds similar that may be tied to internal graphics and a change in the way Bricscad handles it.
    Does your laptop have an extra graphics card you can set Bricscad to use that rather than Intel.
