Paste block (clipboard) with cursor at base point
When copy/paste of a block the cursor is in the lower left limit of the block instead of the the base point like it is when inserting a block. Is it possible to always paste (ctrl-v / pasteclip) a block with the cursor at the base point instead of at the low left corner? I thought this was also standard in previous versions with ctrl-c ctrl-v but unable to find out.
Copy with base point (Copybase)
Already tried that, does not work unfortunately. Does exactly the same as copyclip
It works - just use Snap to insertion as a base point.Nobody reads the manuals anymore.
Hold Shift key down and press right button on mouse, insertion is a snap option then. Else reset your osnap settings.
Or use CTRL-SHIFT-C (= COPYBASE shortcut) instead of CTRL-C and select the point you want to use as insertion point for pasting in the drawing you want to paste into
Hello.
As an addition to the previous answers, something to automate the process could be a custom lisp command like this:
<pre>
(defun c:copyblock (/ ss ent_n ip)
(setq ss (ssget "+.:E:S" '((0 . "INSERT"))))
(if ss
(progn
(setq ent_n (ssname ss 0)
ip (cdr (assoc 10 (entget ent_n)))
(command "_copybase" ip ss "")
(princ)
</pre>
This works with selecting a single block to be copied.
Then, CTRL+V could be used in another drawing to paste the block.
A customization is required because COPYCLIP / COPYBASE are designed to be used for all kind of entities, not just blocks.
If you copy a block or entity to clipboard without selecting a base point, when you paste that entity or block, it will select the lower left of the limits like you experience.
To copy entities from within a drawing, use copy command, and select a base point, or as Alanh said, Snap-Insertion. If no base point is picked, it will default to drawing 0,0,0 point.
To copy entities from one drawing to another, go to Edit-copy base point-pick your base point or snap-insertion. This method copies the entity to the clipboard. Using CopyClip will put the base point at lower left of limits. Using "copy with base point" without selecting a base point does not work in current version, a base point is required. Maybe your version has a bug that has been fixed in newer versions.0
