3D visualization problem
Kentral
edited April 2025 in 3D Modeling
Hi, I don't know why, but when I make a 3D drawing and change the view to hidden or conceptual, it still looks transparent. The edges and objects aren't hidden.
It could be a variable. If I transfer that drawing to another one where things are hidden, then it does.
  • This sounds like an issue with a Visual styles option Opacity. Run VISUALSTYLES command to open Visual Styles section of Drawing Explorer and check your styles.
