Edit Attribute dialog box not filled up
while inserting attribute blocks edit attribute dialog box not filled up text boxes in bricsCAD
  • Could you please create a Support request for this, providing more details and your code, if this is related to LISP?
  • This issue is not for Autolisp it's a BricsCAD issue
  • Work fine for me.
    Do you click "Apply" after entering the text in the attribute field?
  • I am inserting attribute block then we are entering the value, It have already default value of attribute text, it is not selected like AutoCAD, We have to remove default value then enter new value of attribute value. it is possible is will be selected default attribute text so, I can enter value directly with
  • Please help on this issue
    I had a lisp compatibility issue between autocad and bricscad in the past.
    I contacted support and received an answer and solution within a day.
    I really have nothing to add beyond that.
