Changing Drawing Units for BIM Project to Meter
Hi guys,
I am hoping someone can help me out with a solution. BricsCAD BIM functions perfectly with regards to BIM Projects, and with BIMSECTIONS you get the required 2D representation and can use BIM_Tags, etc, as long as it is in mm. However, it gets slightly trickier when I want to draw in meter, and want my 2D to be a meter drawing as well. I have kind of managed to duct-tape together a solution. There's still one problem, and that's the BIMTags. When I put in BIM_Tags, they still come into my drawing super small, and I have to manually adjust the scaling to see them.
Is there a workflow or method by which I can setup my UI or Project in such a way that all my BIM function works for a meter drawing the same way it works for mm? Hopefully its an easy fix, a setting, a systemvariable or such. I would like to hear some other suggestions or solutions.
