Parametric properties issue
Since moving to BricsCAD 25.05 I noticed that I can no longer change the parametric properties of blocks from the properties panel after placing such blocks in a drawing, I am only able to from the rollover menu that pops up when hovering over entities.
When I attempt changing the properties from the properties panel the model is not updated in the viewport and when I deselect and reselect the object the values remain unchanged as was.
It seems like a bug as I did not experience this behaviour prior this version. Pls how can I fix this?
Thank you.
Thank you.
It would be useful to see the drawing with that blocks.0
