please fix briscad dependencies
jtm2020hyo
edited May 2025 in Linux
I tried to install briscad rpm in fedora 42 silverblue using distrobox during the entire day, no luck.
I found same problem because there 3 dependencias are too old, like gtk2 etc.
Could bricscad simply use flatpak or snap or image to install without complications?
  • Could you please report this via Support request?
  • Done.
    If someone already installed bricscad on linux, please tell us how to solve this:
    [doki@lcsCAD ~]$ sudo dnf install ~/BricscadV25.2.05-1-en_US.x86_64.rpm
    Failed to set locale, defaulting to C.UTF-8
    Last metadata expiration check: 10:55:40 ago on Tue May 13 22:39:00 2025.
    Error:
     Problem: conflicting requests
      - nothing provides libclearlooks.so()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
      - nothing provides libdeflate.so.0()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
      - nothing provides libxcb-cursor.so.0()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
    (try to add '--skip-broken' to skip unistallable packages or '--nobest' to use not only best candidate packages)
