import fxb?
Is there any way I can import https://www.fab.com/listings/00f91569-1e6a-413d-bc3e-57219198591a to Bricscad? (fbx format). Does that even make sense? (am a beginner at non-dwg solids)
FBX import is not available in BricsCAD at the moment. Probably, you can do it with some third party applications, that may import .fbx and save the drawing as .dwg.0
The FBX 2013.2 Converter for Windows can be used to convert FBX files to DXF, OBJ, or DAE !
Get the Converter from:
https://aps.autodesk.com/developer/overview/fbx-converter-archives
https://images.autodesk.com/adsk/files/fbx20133_converter_win_x64.exeAll 3 formats can be imported into Bricscad.The car model provided at your Link above has been translated into OBJ and DXF, imported
in Bricscad and saved as DWG, you find attached the DWG files.
hope this helps....
1 -
That's fantastic - thanks0
