Xclip 3d block (bim)
in 2D Drafting
Hello
I have a 3Dblock of an insulation panel I would like to trim (but I want to keep the properties to have the amount of panels needed. Is there a way to do this with for instance Xclip? I cannot get it to work.
Thanks!
Thanks!
Hello.
XCLIP is useful only for 2D geometry.
With a 3D block, you could experiment with adding some parameters to be able to change its configuration.
Maybe, using a visibility parameter could be useful, to only display some of its entities, not all of them.0 -
Hello Virgil,
I haven't thought of that, good idea!
Thx0
