BIM: Typed plans and MEP
Hi.
In the generated drawings or in the Typed plans, is there any workaround how to get eg. flow entities appear as wireframe?
Thanks
Thanks
Hello.
Setting a visual style for a type of entities is not possible with typed plans.
Something of interest could be to display the hidden lines for those entities.To do this, one way of working would be to use the Type(BIM) property to filter the flow entities (Flow Fitting, for instance).
Then you could create a Section result customization and add some settings for the Hidden lines - like color and line type.0 -
Nice idea, thank you.
But how can I let it to not override the color, just the line type style?
