Mouse over transparent hatch
Hi All,
After upgrading to V25 transparent hatches now jump to 0 transparency on either mouse over the hatch directly, or on mouse over a block containing a transparent hatch. We use a lot of transparent hatches for some plans, so now I get a strobing effect when navigating through model space.
I do still want selection preview to be on, it's just the auto hatch transparency changing on mouse over that I'd prefer not to have.
Thanks for the help.
Hello,
In BricsCAD V25.2.01 was introduced the HIGHLIGHT_ALPHA system variable which allows the user to customize the highlight level.
Hi Patricia,
Thanks for getting back to me. Is there any way to just turn off the hatch highlight altogether or essentially make HIGHLIGHT_ALPHA use whatever the existing transparency is?
We use a range of transparency values, so if I set to HIGHLIGHT_ALPHA to 50, it'll remove the flashing for anything set to transparency 50, but will still make any other transparency value flash. I've tried setting HIGHLIGHT to off but that doesn't remove the hatch highlighting / strobing effect.
Thank you!
