BricsCAD pip help
for some reason does not work for me. I need someone to try this
pip ifcopenshell, then try to import a module with 'import ifcopenshell', let me know of you have any error
Cannot be of help, since pip is still not working from BCAD install.
Thanks for trying. With pyrx I get an error while importing ifcopenshell in that sqlite cannot be loaded.
My assumption is that the version of SQLite that is integrated into Python’s std libraries is not compatible with BricsCAD’s custom build. If this is also the case with BIMPYTHON, I’m hoping that Bricsys will attempt to resolve this for V26
