DXFIN and Template drawings
I start my projects almost exclusively with a dxfin command to import field data. Unfortunately this creates a drawing with default settings. Can I set a template to be the default ?
  • ALANH
    edited June 2025
    Why not open your dwt then insert the dxf into it, explode once and purge the old dxf block.
