Draworder does not seem to work
Hi
I used to use draworder in cad to right click and then "bring to front, bring to back" but it appears that the rightmousebutton click is a bit more complicated to modify in BricsCad but ok. I instead do the longer version which is to write it but it seems like it ignores the commands I am giving. Right now, the hatch is visually in front of the lines and I first click the lines and then write "draworder" and make the lines go to front. Nothing happens. Then I try another method, click on the hatch and then move to back, again, nothing happens.
Is there another way to sort this out?
This can be related to the current Visual style - draw order works with 2dwireframe style only. You can check it on the Properties panel when nothing is selected.
