How insert images in BricsCAD for Linux?
                                  in Linux
            I found I can not use Paste Special to insert images, which methods exist to insert images into BricsCAD for Linux without using xref / attached?
Hello. On my end both IMAGEATTACH and IEMBED seem to work without any issues.
1 -
I never used IEMBED; it appears to be able to embed only bitonal TIFF images (white and black)… at least until I can understand it.
Is it not possible to embed any attached color image? I mean, something similar to OLE objects embedded (Windows).0 -
If you want to embed images in a drawing IEMBED is the only option for Linux and unfortunately, yes it wonly works with bitonal TIFF images.
1
