the drawing freezes when I draw lots of holes
Hello,
am drawing a drawing and everything is going as it should,
until I start drawing mass is hols.
I drew them on one side and then mirrored that.
After that, the drawing starts to freeze every 5 seconds.
Is there anything I can do in the drawing or settings, so that it moves well?
There is a command called VIEWRES that might help.
Check if boundary detection is turned on, if it is and every time you hover/move over the area between the holes it will try to detect a contiguous area within all the boundaries and select that. With so many holes this will take some time and may look like freezing.
Turning off boundary detection should solve this problem. You may also want to turn of the other two (prioritize edge and face selection).
Just a comment, the holes you extruded are not proper holes but surfaces. I don't know if that is the intent or not. If you wanted to extrude them as holes then you should be in de solid ribbon tab for extruding them and not in the surface ribbon tab. (I've often seen people accidentally using the extrude from the surface tab instead of the solid tab and wonder why things didn't turn out as intended)
