Civil Survey String Editor - first draft for a bunch of feature requests.
I don't see a forum segment dedicated to Civil Survey so I'll stick with posting in 2D Drafting.
I took a closer look at the String Editor. I have several comments on improving the ease of use.
BCAD String Editor Comments
»UI
add the ability to change column order
make string editor a modeless dialog
Resize editor
Autohide editor
»editing a field
click once and type to replace value
doubleclick to select all then RClick to Copy or Paste
enter moves cursor to next row below
shft+enter moves cursor to next row above
tab goes to next column to right
shft+tab goes to next column to left
set multiple rows to the same value in a column
ie select 4 rows and set -1%grade
»add column for chord bearing
»add link to radius point coordinates field displayed in separate dialog with button to create Civil Point at Radius Point
»add import and export buttons to take all the data in the Editor to and from a .csv file
»add styles with names and properties that can be assigned to a string
string styles control color, linetype, lineweight, transparency, visibility
string styles control vertex display for node type behaviors and properties
As your in AUS I would look at " Stringer" its an Australian product and runs inside Bricscad. It has local support an important feature. You could download the trial but I would get in touch and talk about your questions. They can point you to some Utubes so can see some examples.
Where are you I am near Newcastle NSW. I started with Acad 1.4 yes 40+ years ago ex Civilcad State rep, ex Topcon.
Can talk via PM.
Hi ALANH. I'm actually in the US. I started on AutoCAD 2.52. 1986 ish. I worked for Softdesk/Autodesk in the 90's doing tech support. I was in the Autodesk reseller channel a long time. I helped Florida DOT implement Civil 3D but they are so heavily invested in Bentley the momentum closes their minds to anything else. Today I provide training, tech support, and mostly do project work for a few surveyors and engineers. The Autodesk greed machine has stifled innovation that matters to small firms. Subscription has held everyone hostage. The time is right for BricsCAD to provide automation that everyday CAD operators with homegrown skills can move forward to deliver the best results for their clients. They can move beyond dumb drawings to provide asset managers with quality basemap data.
1
