How to get Length propery of a slab
I can get standard BIM properties from a slab with bim:get-property, like Composition and Load bearing, but not Slab Base Quantities like Length, Width.
How to get Length, Width etc. ?
If its possible I would like to get the Depth of the different plies.
If you have a solution: Thank you in advance,
Jan Cartigny
Hello.
You could use something like this to get some dimensional BIM properties:
(vl-load-bim)
(setq length (bim:get-property <entity-name> "SlabLength"))
(setq thk (bim:get-property <entity-name> "Thickness"))
(setq width (bim:get-property <entity-name> "SlabWidth"))
(setq width2 (bim:get-property <entity-name> "Width"))
(setq depth (bim:get-property <entity-name> "SlabDepth"))Note that these properties are related to calculating quantities.
Their values are approximative.
These properties are not precise geometric properties.If the slab has a composition assigned, then the thickness won't be available.
In this case you need to maintain a list with compositions and their thicknesses.
There are no functions (not lisp functions, at least) to query the structure of a composition.You can find the name of the assigned composition using:
(setq comp (bim:get-property <entity-name> "Composition"))
