Creating the sheets
Hello,
I am creating the sheets for presentation, but I'm having difficulties with the elevation sheets.
I have a building modeled, which is an elevated water reservoir, and I also have the hydraulic system modeled both inside and outside the building.
The elevations are already done and the sheets are as well, but the problem occurs when I include the hydraulic system (either via Xref or even as a block). When I include it, the sheet comes out incomplete. If I leave out the hydraulic system, the sheet is created correctly.
I’m attaching a PDF to explain the issue more clearly.
Thanks,
Susana Silva
