Civil Points entities in lisp
Hello
A want to create a lisp that uses Civil Points as input (the user selects some civil points and then some things will drawn).
I firstly want to access the civil points using lisp so to get their Easting, Northing, Elevation and Raw Description. Any help to this direction would be welcomed.
  • Do you mean to string the points using a pt description ? I have started to do something.
    Some sample data code. The string 01F will be joined to all 01F's and so on.
    1
    921.889
    4915.96
    48.25
    01F
    2
    967.024
    4921.68
    49.39
    01F
    3
    1045.51
    4921.584
    52.09
    01F
    4
    1126.961
    4941.48
    54.36
    01F
    5
    1123.036
    5051.04
    56.34
    01F
    6
    976.679
    5005.819
    50.53
    TR
    7
    1047.843
    5074.345
    56.26
    01BB
    8
    1000.876
    5079.2
    54.62
    01F
    9
    896.378
    5054.56
    51.03
    01F
    10
    892.944
    4978.88
    48.94
    01F
    11
    913.884
    4913.589
    48.12
    01EB
    12
    991.606
    4917.719
    50.21
    01ET
    13
    997.129
    4919.734
    50.32
    05F
    14
    985.194
    4955.816
    49.03
    01ET
    15
    969.494
    4984.416
    49.42
    01ET
  • George1
    edited July 2025
    No I don't mean that.
    I mean every entity (line, text etc) has properties (for a line these properties are layer, linewidth, start coordinates, etc) that can be retrieved through auto lisp. I want to retrieve the properties of Civil Points, that can be Easting, Northing, etc.
  • use getpropertyvalue
    (getpropertyvalue (car(entsel)) "Easting")
  • As a side note, I recently added a KD-Tree in Python to aid in working with generic 3d points, but you should be able to use civil points to, since the tree returns the index
    import traceback
    from pyrx import Ap, Ax, Db, Ed, Ge, Gi, Rx, Cv
    @Ap.Command()
    def doit() -> None:
        try:
            filter = [(Db.DxfCode.kDxfStart, "BSYSCVDBPOINT")]
            ps, ss = Ed.Editor.select(filter)
            if ps != Ed.PromptStatus.eOk:
                raise RuntimeError("Selection Error! {}: ".format(ps))
            #get the cv points and ge points,
            cvpnts = [Cv.CvDbPoint(id) for id in ss.objectIdArray()]
            gepnts = [cvpnt.position() for cvpnt in cvpnts]
            # is a nanoflann tree
            tree = Ge.Point3dTree(gepnts)
            #search
            idxs, dists = tree.knnSearch(gepnts[0], 2)
            for ind in idxs:
                if ind == 0:
                    continue
                print(
                    cvpnts[0].easting(),
                    cvpnts[0].northing(),
                    cvpnts[0].elevation(),
                    cvpnts[0].fullDescription(),
                print(
                    cvpnts[ind].easting(),
                    cvpnts[ind].northing(),
                    cvpnts[ind].elevation(),
                    cvpnts[ind].fullDescription(),
                Ed.Core.grDraw(gepnts[0],gepnts[ind],1,0)
        except Exception as err:
            traceback.print_exception(err)
  • Thanks. It works.
    Do you know the property name of Point row description? I have tried Pointrawdescription and several other similar names but they don't exist.
  • I think there’s a function that will give all the possible properties for an entity
    https://developer.bricsys.com/bricscad/help/en_US/V23/DevRef/index.html?page=source%2FgetPropertyValue.htm
  • Yes it's dumpAllProperties. Thanks again!
  • Also use dumpit.lsp then say (vlax-get obj 'property) it will become one of those must have lisp.
    ;;; DumpIt ;
    ;;; Dump all methods and properties for selected objects ;
    (defun C:Dumpit ( / ent)
    (while (setq ent (entsel "\n pick object "))
    (vlax-Dump-Object
    (vlax-Ename->Vla-Object (car ent))
    (princ)
    ;(dumpallproperties (car (entsel)))
  • Jason Bourhill
    edited July 2025
    This function will print the properties of selected civil points out to the screen
    (defun C:CivilPointInfo ( / sset ptEname)
    (cond
    ((vl-load-civil) ; Load the Civil API. requires BricsCAD Pro or greater
    (princ "\nSelect Civil points to get info on: ")
    (setq sset (ssget '((0 . "BsysCvDbPoint")(410 . "Model")))) ; allow selection of only Civil points
    (cond
    (sset
    (foreach ptEname (vle-selectionset->list sset) ; foreach civil point
    (princ "\n---------------------------------------")
    (princ "\nCivil Point Number: ")(princ (civil:point-get-number ptEname))
    (princ "\nName: ") (princ (civil:point-get-name ptEname))
    (princ "\nRaw Description: ")(princ (civil:point-get-rawdesc ptEname))
    (princ "\nFull Description: ")(princ (civil:point-get-fulldesc ptEname))
    (princ "\nDescription: ")(princ (civil:point-get-description ptEname))
    (princ "\nPosition: ")(princ (civil:point-get-position ptEname))
    (princ "\nEasting: ")(princ (civil:point-get-easting ptEname))
    (princ "\nNorthing: ")(princ (civil:point-get-northing ptEname))
    (princ "\nElevation: ")(princ (civil:point-get-elevation ptEname))
    (princ "\n")
    (T (princ "\nNo Civil points selected"))
    (T (princ "\nSorry you need BricsCAD Pro or greater to work with Civil Points"))
    (prin1)
    CAD Concepts Ltd
    cadconcepts.co.nz
