Help Needed: Creating Large Ribbon Panel Icons
The Ribbon Panel Button icons I create are much smaller (similar to the toolbar buttons) and do not match the larger sizes of the default buttons.
Please share tips on creating larger Ribbon Panel Button icons.
Thanks,
Clint
Hello.
You could use the Customize dialog box and activate the Ribbon tab.
Then expand the Panels node, navigate to the panel you want to edit, and expand its node.After selecting a button in the tree, there are some properties available to edit, in the lower part of the dialog.
One of the properties is Button Style.
There are two main categories available for this property - Small and Large.
You could experiment with using Large - it might be more suitable for your project.
1 -
Hello and thank you Virgil! No doubt, this is something I overlooked!
