Multileader leader shifts when final clicking
Our multileaders default settings are set up to attach to the middle of the top line for left and right attachment. Creating a multileader and placing text to the right works fine, the leader can be made exactly horizontal. However, when wanting to place the text to the left i.e. a right attachment, upon making the final click, the line jumps up from horizontal like it's making room for a line of text. Weird.
When I change the default settings for the right attachment to "middle of the bottom line" it works perfectly, however, now I have to change the attachment position.
Which BricsCAD version do you use? It would be useful to see your example drawing. It can be reduced drawing with a necessary Mleader style and example of correct and wrong Mleader.
There has been lots of fixes applied to multileaders in recent BricsCAD versions. Generally it is has been annotative multileaders that have been most problematic. Your issue looks similar to the description of a fix documented in the V25 release notes.
If you aren't running BricsCAD V25, then I would suggest that you download and test behaviour in it. If you find the issue is still present in V25, then I would recommend that you raise a support request to get the problem investigated.
CAD Concepts Ltd
