Alignment point exporting
I have an alignment that I'd like to export the chainage and levels from into a text file. Can this be done in Civil, or do I need an add-on to do this?
Not sure about defualt Civil, but Civil Site Design runs inside Bricscad Pro, it has way more options being a full function Civil design package, Roads, Drainage, Sewers and Surfaces. Your request can export a points file for all points in a cross section handy for road set out. Lots of Utubes showing functionality.
Thank you. I was hoping I wouldn't need to spend more money to get it to work.
Hello.
You could experiment with the LandXmlExport command.
This creates an xml file containing data from the alignment, which, depending on the design intent, could be further processed into something useful.
