Cannot make pointcloud unselectable when using edit commands
Hi -
I have an issue with Bricscad pro 2025 (2026 beta) - when I have a pointcloud inserted in a drawing and I use an edit command such as fillet, the pointcloud is still trying to be selected even though it is in a locked layer and I have pointcloud selection off (3DOSMODE).
It works correctly in version 2024 and I have compared settings with each version and they seem to be the same.
Can some please help?
  • Hello.
    In my testing, filleting worked fine and the point cloud didn't interfere in the process.
    This, assuming that the point cloud layer was locked.
    The first thing to try would be to create a new user profile from scratch and test again.
